It is currently Wed Jun 25, 2025 11:37 pm All times are UTC + 10 hours
[ 5 posts ] |
archelo
Post subject: Taigen Tiger TK22 Airsoft Problem Posted: Sat Jan 09, 2016 2:30 pm |
Hello everyone. Im new to this forum and really looking forward to learning from the experts! I was told that this is the place to come for RC Tanks so here i am.
I have a Taigen Tiger 1 Metal Edition with a Clark TK22 and a Turnigy 9x running the TankER9x software. I was having some problems getting the Airsoft to fire and discovered that the gun was wired backwards so all it would do was click. Once I figured that out, I have run into another issue and cant figure out how to correct it. Here goes....
The barrel elevation is activated by moving the left stick up one dash and either moving left or right proportionally. The problem is that when I try to fire the cannon (left stick up one dash and slightly to the right), it also activates the elevation control so the gun fires as the barrel is moving up or down. Is this a radio programming issue or an issue with the tank wiring? Is there a way to reprogram the 9x so that i can fire the gun by moving the left stick straight up?
I hope this explanation makes sense and really hope one of you may know whats going on because its useless to try hitting a target while the barrel is moving. Anyway....would really appreciate any help you guys can offer.
Thanks! Archie
archelo
Post subject: Re: Taigen Tiger TK22 Airsoft Problem Posted: Mon Jan 11, 2016 12:42 pm |
archelo
Post subject: Re: Taigen Tiger TK22 Airsoft Problem Posted: Tue Jan 19, 2016 11:15 pm |
Problem solved. It was the wiring of the elevation motor.
Post subject: Re: Taigen Tiger TK22 Airsoft Problem Posted: Wed Jan 20, 2016 6:10 am |
Hey Archie, Good to hear you got it solved.
I'm back at my desk in Australia so I'll be able to get back onto support as normal.
archelo
Post subject: Re: Taigen Tiger TK22 Airsoft Problem Posted: Wed Jan 20, 2016 6:25 am |
Thanks Kevin. Welcome back! Hope you had a great holiday.
Now that the Tiger is up and running, im working on the KV-1. More wiring issues with the elevation and airsoft firing that hopefully I can sort out in the next few days. Different issue than the Taigen so Im going to try and copy the wiring to make it identical. Anyway...if I get stuck, I will open a new thread.
Thanks again! Archie
[ 5 posts ] |
