RC Tanks Australia Forum • View topic - Jeep Willys and Bantam 1/4 t Trailer
Board index » British Tanks » 1/16 Scale Builds
Post new topic Reply to topic  [ 10 posts ]
 Post subject: Jeep Willys and Bantam 1/4 t Trailer
 Post Posted: Fri Jan 17, 2014 7:04 pm
Hi,
I also have completed the US Army equipment with a M4 Sherman, a M16 Half-track and a Banbury Mint Willys Jeep with a 1/4 t Bantam trailer.
The modificalions made on the Banbury Jeep to done it RC will be posted later
with pictures to explain how to do the this modifications.
Best regards.
Boris
 Post subject: Re: Jeep Willys and Bantam 1/4 t Trailer
 Post Posted: Fri Jan 17, 2014 7:50 pm
Hi,
the M 4 105 Howitzer Sherman is from French 2e Division Blindée ( Gen. Leclerc ) 501e Régiment de Chars de Combat, head quarter company.
The M 16 Half-track is from 1e Armée Française ( Gen. de Lattre de Tassigny ) 3e Division d'Infanterie Algérienne
( Gen. de Monsabert ) 37e Groupe FTA ( anti aircraft platoon ).
The Jeep is the personal vehicule of Capitaine Dronne ( 2e Division Blindée, 9e compagnie du
Régiment de Marche du Tchad, first allied vehicule to enter in Paris the August 24 1944, the famous inscription on the jeep means " death to fucking cunt " for which Gen. de Gaulle said " Vast Program " !
Best regards.
Boris
 Post Posted: Sat Jan 18, 2014 8:50 pm
Hi,
to make a RC Danbury Jeep you need one Jeep and one 1/24 scale Sumo Crawler for the motorisation
first, dismantle the Jeep, made a rubber mould to cast plastic additional rear wheels. They will be necessary to make the Bantam 1/4t trailer.
Make a hole in the jeep floor between the seats at the dimensions of the Sumo motor.
continuation on next post.
Regards.
Boris
 Post Posted: Sun Jan 19, 2014 12:28 am
Hi,
Jeep continuation :
Grind the chassis to make place for the gearbox and transmission shafts :
Regrds.
Boris
 Post Posted: Sun Jan 19, 2014 12:47 am
Hi,
next, make the suspension springs : 2mm x .5 flat temper steel
and sold small tubes 1mm inside on the springs to pass through
1mm dia. brass bar holding the differential front and rear boxes:
Wait next !
Boris
 Post Posted: Sun Jan 19, 2014 1:46 am
Hi,
the suspension springs are mounted on the chassis by means of 1mm screws and nuts and
1mm dia. brass shackles.
the 1mm dia. brass bar pass through the welded tubes on spring and the 2 trunions of the
differential boxes.
To block the rotation of the rear wheel axles, two short links are fastened between
the wheel hub and the differential box.
The steering servo is glued against the inside of the right chassis spar.
Reassemble the jeep and insert the RC receiver under the chassis along the left spar
and glue the main switch under the chassis just in front of the gasoline tank.
The next post will descibe the electrical supply.
Boris
 Post Posted: Sun Jan 19, 2014 2:11 am
Hi,
as it is impossible to insert 4 AA batteries into the jeep, I have made a Bantam 1/4t trailer
in which it is possible to put batteries, it is the reason of the 2 supplementary wheels I've made :
The electrical connection between the trailer and the jeep is made of coaxial wire
and SMB connectors.
Boris
 Post Posted: Sun Jan 19, 2014 2:41 am
Hi,
the end !
Hope that this drawing and explanation will be of some interest to 1/16 RC modelers
who want to increase their collections of RC US tanks.
Best regards.
Boris Plotnikoff
 Post Posted: Sat Mar 14, 2015 6:32 pm
Hello from Denmark
WOW great made,, Thanks,,do you Think this Will be better to use ,Than a lose 1/24 micro trekker,,
I reale enjoy this build
REGARDS Bernhard
 Post Posted: Sat Mar 14, 2015 7:12 pm
Hello from Denmark. Great build super Nice Thanks Boris
Do you Think the , sumo is better to use Than a lose trail trekker ,1/24 . And where have you get the driver from,
REGARDS
Bernhard
Users browsing this forum: No registered users and 6 guests
