It is currently Fri May 03, 2024 7:18 am All times are UTC + 10 hours
[ 2 posts ] |
couch spud
Post subject: radiolink t4eu 6 channel with rc5hl Posted: Sun Apr 24, 2016 11:11 pm |
hi everyone, bought the rc5hl from the rcta shop so I could get rid of the heng long transmitter, I've only got a cheap radiolink radio, initially bought for a rc boat but I thought give it a go. It works fine with the rc5hl, left hand switch on top of the radio is channel 5, pull it forward tank starts up then push it back to the off position, same to turn it of,f on the levers I have it set as left lever up----forward left lever down---reverse left lever left---turns left left lever right---turns right
right lever up part way---barrel elevation--- fully up---machine gun right lever down part way---barrel elevation---fully down on my tank fires airsoft right lever right --- turret turns right right lever left---turret turns left when the radio is first turned on ( without the tank turned on ) move the throttle lever full forward than back to full reverse then centre it, this cancels the failsafe hope this is helpful, i'l try to post a few pictures
best regards John.
couch spud
Post subject: Re: radiolink t4eu 6 channel with rc5hl Posted: Mon Apr 25, 2016 1:27 am |
couple more.
[ 2 posts ] |
