2.4 gHz Adapter for Heng Long Tanks - RC2HL http://www.rctanksaustralia.com/forum/viewtopic.php?f=149&t=326 |
Page 8 of 9 |
Author: | Phyrephish [ Fri Jan 11, 2013 8:21 pm ] |
Post subject: | Re: 2.4 gHz Adapter for Heng Long Tanks - RC2HL |
HI TeckP. The LED should be on. It turns and stays on as long as there is a valid signal being received from the receiver. Cheers Kevin G |
Author: | Phyrephish [ Sun Feb 10, 2013 8:25 pm ] |
Hey All It's probably about time to make a more 'official' announcement on the developments that have been going on with the RC2HL unit. The most significant development is that the new RC2HL V3 boards are now compatible with the Turnigy 9X8Cv2 receivers. The previous incompatibility problem was not the fault of the RC2HL but rather with the Turnigy receiver. The 9X8Cv2 receivers do not transmit the channel information/signal in the correct order. Rather the 8 channel receivers transmit in the following order CH1 CH3 CH2 CH4 The timing of channel 2 and 3 is reversed (credit to ancvi_piii), actually all of this is of credit to ancvi_piii. Hence a few little additions/changes have been made to the RC2HL board to allow for operation with the 8 channel receiver. The first is the addtion of a jumper next to the RX18 input plug. This jumper must be closed if using the 8 channel receiver and open for use with the 6 channel HKT6A receiver. Secondly, the cabling is different. Channel 2 from the receiver must be plugged into IN3 on the RC2HL and Channel 3 into IN2. In addtion to this 'fix' the RC2HL now offers two addtional 'switching' functions throught the ports S1 and S2. S1 can be used to operate a relay and hence switch on/off the headlights or smoke unit or anything else. S2 is configured as an automatic reverse light. Instructional Videos are on the RCTA Youtube Channel RC2HL V3 Basic Install RC2HL V3 Extra Functions Cheers KG |
Author: | stolzie [ Tue Feb 12, 2013 2:26 pm ] |
That is awesome news! Might have to invest in one of these so I can get some tank action. Cheers, Jason |
Author: | Phyrephish [ Sat Mar 30, 2013 8:23 am ] |
Author: | ARROWSKARTAX9 [ Mon Aug 12, 2013 8:20 pm ] |
Hello, I would like to upgrade me Heng long King Tiger Porsche Turret Metal Upgrade to 2.4ghz. As I am new to RC Tanks can some one please point me in the right direction. Thanks, Chris. |
Author: | Admin [ Tue Aug 13, 2013 7:55 pm ] |
Hi Chris, If you are wanting to upgrade to 2.4gHz operation make sure that you upgrade to a proper Hobby Grade 2.4 gHz system. Do not be fooled by the offerings by Taigen or Heng Long. They may operate on 2.4 gHz but the Taigen system at least does NOT conform to the usual standards. This means that you will not be able to take advantage of the squillions of products out there designed for the R/C hobby. The first place to start is with a good radio and in my opinion there is nothing better for tanks than a Turnigy 9X running custom firmware. I am certainly biased here but there is nothing better for the money than a 9X or 9XR running tankER9X. What is so good about tankER9X: -Allows you to assign the wide variety of switches, pots, & sticks to anything you desire allowing for great control options for your tank -Has a number of templates to allow for easy setup of tank control boards - the latest release of tankER9X replaces all the confusing plane terms with tanks ones for ease of use RUD (Rudder) is STR (Steering) in tankER9X THR (Throttle) is MTR (Motors) in tankER9X (some versions may have this as ACC for acceleration) ELE (Elevator) is GUN (Gun control) in tankER9X AIL (Aileron) is TUR (Turret control) in tankER9X - adding to all of this you get PC connectivity via a separate USB programmer. Here is a little video showing how quick and easy the conversion can be using the 9X and our RC5HL control board Tank ready 9X or 9XR radios can be bought from the RCTA webshop http://rctanksaustralia.com/shop/index. ... ucts_id=25 http://rctanksaustralia.com/shop/index. ... cts_id=223 Once you have a good radio you can then choose form a variety of tank control boards. Our RC5HL is probably the cheapest option as it makes use of your existing RX18. However there are a wide variety of options out there depending on the depth of your wallet and skills as a modeller. Cheers Kevin G |
Author: | ARROWSKARTAX9 [ Tue Aug 13, 2013 8:48 pm ] |
Hi Kevin, Thanks for replying. And upgrade to 2.4 ghz as you have given me some good info. Thanks again, Chris. |
Author: | ARROWSKARTAX9 [ Wed Aug 14, 2013 9:58 pm ] |
Ok Kevin. What do i need to make my tank 2.4ghz ready. Can you please list all the parts that i would need and i will get them ordered. If their is anything else i need can you also list them as well. Thanks Kevin, Regards, Chris. |
Author: | ARROWSKARTAX9 [ Mon Aug 19, 2013 10:02 pm ] |
HI Kevin, I am going to order the, Turnigy 9x upgraded radio RC5HL Turnigy 2650 Reciever pack Do i need the self centering lever. Could you also please advise me of anything else that i might need and i will put my order in, Thanks Kevin, Regards, Chris |
Author: | Admin [ Tue Aug 20, 2013 9:02 pm ] |
Hi Chris No you do not need to order the lever when you buy the radio. It is installed as part of the upgrade on both the 9X and 9XR. If you are comfortable with computers then the USB programmer would be worth a look. TankER9X has been upgraded from the Bastille version and the new version is going out on new radios. There has been a bit of activity with ER9X so there is likely to be a few more enhancements between now and the end of the year. If you want to use the RC5HL functions to switch headlight or Machine Guns or whatever then maybe the relay unit? Cheers Kevin G |
Page 8 of 9 | All times are UTC + 10 hours |
