RC Tanks Australia Forum • View topic - Help setting up the RC2HL
Post new topic Reply to topic  [ 2 posts ]
 Post subject: Help setting up the RC2HL
 Post Posted: Fri Feb 01, 2013 7:09 pm
Finally got around to getting a second Turnigy 9x to use just for tanks but have run into a bit off a problem. The lights on my HK V2 6 channel receiver and the RC2HL turn on but the main light on the HL tank just flashes.
I have done the following
- Double check all power and receiver connections
- Checked that I had the correct HK V2 receiver
- Made sure the 2 cell Lipo is charged
- used the Tamiya template in the Tank ER9x and inverted channels 2 to 4
Does anyone have any idea what I've done wrong?
 Post subject: Re: Help setting up the RC2HL
 Post Posted: Fri Feb 01, 2013 9:04 pm
Hi TeckP
First up see below for the RC2HL setup...
Although the Tamiya Template should work you should also have had as an option a specific RC2HL template. The Tamiya template only allows for turning the tank on using the left stick. The RC2HL template has the Engine ON/OFF, magine gun and Cannon all assigned to switches. Have you watched the video on the RCTA youtube channel on how to apply templates correctly? It is a bit tricky.
I assume that you have been trying to turn the tank on by moving the left stick to the bottom right. The tank should turn on when you see the display like below
Lots of how to videos with the RC2HL, Turnigy (X and the HKT6A receiver on our youtube channel
http://www.youtube.com/user/rctanksau
Users browsing this forum: No registered users and 9 guests
