It is currently Fri May 17, 2024 2:02 am All times are UTC + 10 hours
[ 6 posts ] |
Admin
Post subject: TVC-TRF10 Premium Control Modules Posted: Wed Aug 31, 2011 6:33 pm |
Premium Tank Control Modules - TVC-TRF10 Series
Available NOW in the RC Tanks Australia Shop
Premium control module for 1/25 to 1/16 scale tanks. Available for the following models:
HT1: Tiger 1 HT2: T-34 HT3: Panther HT4: Stug III HT5: Panzer III HT6: Walker Bulldog MT1: Leopard 1 MT2: Leopard 2 MT6: Abrams MT9: T-55
Overview: The module controls the following functions: • Proportional control of acceleration and steering • Proportional control of turret rotation and main cannon elevation • Support for servo control of turret rotation and cannon elevation • Servo or motor control for cannon recoil • Cannon LED flash • Machine Gun LED • Polyphonic sound to all functions (start the engine stop / "Idle", 14 steps, main weapon, gun, turret rotation) • Automatic control of brake lights, reversing lights, Flashing lights and rotating light (running light) • Model switching of up to three models • Automatic, independent control of smoke unit • IR Battle-function with additional BU module (Tamiya compatible) • Heng Long Adapter avaiable for a pracatically solderless upgrade of Heng Long Tanks
The controller is typically suitable for 1:16 tank models. For models of greater scale (up to 1/4 scale) the modules should be used in conjunction with a TVC - B series controller of appropriate power.
Costs: TVC-TRF10 - $249 AUD TV-HRF-BU (Battle Unit to convert existing Heng Long system to Tamiya capability) - $25 AUD
reyemmanuel
Post subject: Re: TVC-TRF10 Premium Control Modules Posted: Thu Sep 01, 2011 1:11 am |
Willys MB Driver |
Joined: Thu Sep 01, 2011 12:59 am Posts: 21 Location: Newcastle, NSW
This is great news. Any timeframe where this could be available...My Abrams is itchin' to have a go at this.
It'll be good if more info (i.e. url) or any document wherein we can compare how this would fair with El Mod, SLU, DBCs, Tam, Impact, IBU.
Fingers crossed, I hope this would have: 1. at least 4 classes (DBC), or better yet SLU style (3-12 hits) 2. SLU style battle control with adjustable ammo and IR sensitivity 3. takes 50% decrease in speed upon first hit (Tamiya, DBC), unlike SLU 4. momentum simulation similar to DBC. 5. model switching easier than El Mod 6. extended combat mode similar to EL Mod 7. IR range adjustment and/or extender similar to impact 8. repair function similar to IBU
Amen!!!
reyemmanuel
Post subject: Re: TVC-TRF10 Premium Control Modules Posted: Thu Sep 01, 2011 1:24 am |
Willys MB Driver |
Admin
Post subject: Re: TVC-TRF10 Premium Control Modules Posted: Thu Sep 01, 2011 8:01 am |
Hi Reyemmanuel
As much of the information you have asked for will be available soon. If you are able to understand German then it is available now. Below is a grab from the manual about the battle system.
In short 4 classes Car or truck - 1 hit - destroyed Light Tank - 3 hits - destroyed Medium Tank - 6 hits - destroyed Heavy Tank - 9 Hits - destoyed
Yes tank mobility and function are decreased as you sustain more hits
Reload & Repair time also set to class.
No there is not the extended system of ElMod since the Tami & HL mushrooms only have a single sensor.
You will be able to order very soon. However, all first up orders will be combined with the first shipment for the store so there will be short delay as the first units will have to be shipped from Germany first.
Post subject: Re: TVC-TRF10 Premium Control Modules Posted: Sat Oct 29, 2011 2:04 pm |
Post subject: Re: TVC-TRF10 Premium Control Modules Posted: Sun Oct 30, 2011 8:33 am |
Very Glad to hear Work has been continuing on making the best possible match between the SGS modules and the tankER9X firmware. Since your tank was done the inertia simulation has been greatly improved. Best of all is that all you need to do is to add the new settings to your Tiger Mix add adjust the values to your taste. Cheers
[ 6 posts ] |
