It is currently Sun May 05, 2024 4:31 am All times are UTC + 10 hours
Darryl Usher
Post subject: Re: Turning trim Posted: Fri Jun 15, 2012 8:06 am |
Thanks Kevin The plug is all the problem but the pin spacing is the same. This is my second elmod Pro, after the first one died at a tank show. The first one was fine is all functions. The second one has all the troubles. You turn on the power, tank and TX the order makes no difference. You can now turn on the engine sound. The tank should not move, but it did the tracks moved at high speed. They sent me a new program that stopped this. Now I have this mixing of steering and throttle problem. I have decided to send it back. Darryl
Darryl Usher
Post subject: Re: Turning trim Posted: Tue Aug 07, 2012 10:42 am |
I used my Airtronics stylus on 22 and it worked the same as the 2.4 with my XPS 2.4 conversion. So I sent it back, they say it works fine. Is anyone using Airtronics 8 ch with Elmod? I have an old Futaba FG and I will try that when I get the tank controller back. This radio is before computers, pots for end points. Darryl
