hajime42
Post subject: Re: First pics of first production board Posted: Sat May 09, 2015 11:02 am |
Joined: Wed Apr 10, 2013 11:59 pm Posts: 50 Location: Japan
XHi Kev, That's great!! Yes I have 9XR and running Tank ER9X. You thought me how to install the firmware remember? My usb programming cable also came from RCTA.
Oh great! Really just can't wait!! Oh Kev, can you put the long engine start sound for bovington tiger?
Cheers, Hajime
Post subject: Re: First pics of first production board Posted: Sat May 09, 2015 1:10 pm |
Hajime, You can put any special startup sounds that you wish. I'll probably have a more general sound set release. But all you or anyone has to do is make the wav file and name it (or anything else after "001_" 001_StartUp1_BovingtonTiger and copy it to the SD card for Module A.
hajime42
Post subject: Re: First pics of first production board Posted: Tue May 12, 2015 9:44 pm |
Hi Kev. So, when will the ASP be available?
Cheers Hajime
Post subject: Re: First pics of first production board Posted: Wed May 13, 2015 8:24 am |
I can ship you a unit today if you want. However, you would need to supply your own SD cards as I am waiting for a supply of cards to arrive. You would then have to download the sound sets and copy them to your cards.
I'm giving the cards til Friday to arrive and regardless I will have the pricing an options up in the store over the weekend.
hajime42
Post subject: Re: First pics of first production board Posted: Wed May 13, 2015 9:16 pm |
Hi Kev. Okay, maybe I'll just have to wait till this weekend. After the weekend, you could send me an invoice through paypal if ASP is still cannot be obtained from the online store.
Cheers, Hajime
hajime42
Post subject: Re: First pics of first production board Posted: Sat May 16, 2015 9:08 am |
Good morning Kev, Do I have to add a sirvoe board to be able to use servo recoil?
Cheers Hajime
Post subject: Re: First pics of first production board Posted: Sat May 16, 2015 5:32 pm |
Hi Hajime
Depends on if you have a 9X and what you want to do with Channel 8. You can change the existing mix on CH8 from operating an elevation servo to operating a recoil servo. In such a case then NO you wouldn't need a Sirvoe board.
BTW the recoil servo mix has always been provided in tankER9X and is found on CH7 of a RC5HL template - Just copy
The Asp template/model settings eepe file will have a recoil servo setup on CH11 all you would have to do is swap CH11 with CH8 if you don't need the elevation servo.
hajime42
Post subject: Re: First pics of first production board Posted: Sat May 16, 2015 7:05 pm |
Okay Kevin thanks a lot.
Thor91172
Post subject: Re: First pics of first production board Posted: Sun May 17, 2015 7:42 am |
Kevin
Just ordered mine.Thank you for your diligence.
John
Post subject: Re: First pics of first production board Posted: Sun May 17, 2015 11:45 am |
No - THANK YOU - for all of your patience waiting for this darn thing to be ready. Cheers KG
