Finally here are the update files for Asp1 to give it almost all of the functionality of Asp2
ASP1_1608_updates.zip
Try getting free files to update your IBU2 to IBU3 functionality or a TK board to the next level up
But you bought an Asp - you were pretty smart.
There are read me files in the update so please read them.
The update assumes that you have moved the elevation motor off of the 8-pin connector and onto it's dedicated port OR you are using a servo for elevation. It also assumes that you are not using a REMORA (I don't think anyone is) as the is now a recoil servo signal on the old Remora port - NO NEED for a Sirvoe board. You can plug a servo direct into the old Remora port on the underside of Juno.
DKLM gearbox support also available and is selected in test mode - use a toothpick to toggle the IR/Airsoft mode switch. Sorry but that was the best solution I could come up with. Best to access test mode using your RADIO as test mode now has voice support and you need your Juno board attached.
