RC Tanks Australia Forum • View topic - FINALLY - November 2016 Asp2 Updates
Post new topic Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
 Post subject: FINALLY - November 2016 Asp2 Updates
 Post Posted: Tue Nov 15, 2016 8:19 pm
November 2016 Aps2 Update
- Quite a number of improvements (will list soon)
Nov_2016_Asp2_Update.zip
Zip file contains the latest version of firmware for ALL microcontrollers on the Asp2, Juno & Manta boards.
Use the app available here:
http://www.picaxe.com/Software/Drivers/ ... mmer-App/#
USB programmers available in webshop OR follow the guides here on forum to make you own.
 Post subject: Re: FINALLY - November 2016 Asp2 Updates
 Post Posted: Wed Nov 16, 2016 9:24 am
 Post Posted: Wed Nov 16, 2016 5:46 pm
Excelent news :)
 Post Posted: Sun Nov 27, 2016 12:23 pm
Thank you Kevin!
I just got a notification about this thread now.
I don't see this listed, remember how in the past you explained you will change the programming so the sounds are initiated before signals are sent to motors? Was this implemented here? Because no matter what I do, the sounds coming from my asp2 are always coming about a split second after motions are initiated, not just from motors, but also turret rotation and elevation. All sounds are starting slightly after movements are already started. Not by much, but definitely noticeable.
HL M41 Bulldog
Torro Late Tiger I
Taigen KV-1
Wish List:
Torro KingTiger
Panther F or G
Taigen T34-85
Super Pershing
 Post Posted: Sun Nov 27, 2016 12:39 pm
Also, you explained we can add 4 cannon sound files, but the update only allows using 3 separate cannon sounds, so what's the 4th sound file for?
Also, how do we initiate the separate cannon sounds?
Main cannon sound 1 - 100% on ch7
Main cannon sound 2 - 70% on ch7 ?
Main cannon sound 3 - ? on ?
HL M41 Bulldog
Torro Late Tiger I
Taigen KV-1
Wish List:
Torro KingTiger
Panther F or G
Taigen T34-85
Super Pershing
 Post Posted: Mon Nov 28, 2016 9:59 am
Yes 4 more cannon sounds (2 x 2 =4) - REMEMBER the Cannon sounds are in banks of 2. A random one of those 2 is played each time you fire. If you only want the same sound copy it to BOTH spots.
Canon 1 sounds = sounds 25 & 26 on module B (original 2 only)
now the 4 new sounds (121 - 124 on ModB)
Cannon 2 sounds = sounds 121 & 122 on Module B
Cannon 3 sounds = sounds 123 & 124 on Module B (airsoft ONLY)
So in summary an airsoft user can fire using
100% and have one of two different sounds play (25 or 26)
or
75% and have one of two different sounds play (121 or 122)
or
50% and have one of two different sounds play (123 or 124)
IMPORTANT at 25% on CH7 the emergency brake is activated.
 Post Posted: Mon Nov 28, 2016 10:47 am
Ok, thanks for explaining the cannon sounds, Kevin.
How about the question in my earlier post. Was this implemented in the update?
HL M41 Bulldog
Torro Late Tiger I
Taigen KV-1
Wish List:
Torro KingTiger
Panther F or G
Taigen T34-85
Super Pershing
 Post Posted: Mon Nov 28, 2016 3:04 pm
yes
 Post Posted: Tue Nov 29, 2016 1:38 am
Excellent! Thank you.
HL M41 Bulldog
Torro Late Tiger I
Taigen KV-1
Wish List:
Torro KingTiger
Panther F or G
Taigen T34-85
Super Pershing
 Post Posted: Sat Jan 07, 2017 5:36 pm
I had no time to work on anything for the last 2 months or so due to the holiday season, and only now I'm getting back into finishing everything up. I'm getting ready to update ASP2 with your new firmware. I got the FTDI breaker board all set up, all connectors, etc. but absolutely cannot find where to connect it on ASP2. The original video is showing ASP, and ASP2 is redesigned, so using the JST-ZH port, but I can't find any instruction showing exactly which port, and what polarity should be connected in (RX, GND, TX).
The best I found is this download/file.php?id=1939
which shows update ports, but shows 2, so I still don't know which is the correct one, and in what polarity the leads from the FTDI breaker board should be connected.
Also, any instructions on using the picaxe to load all the axe files from your Nov_2016 update zip? Should I just go file by file through each folder, loading all the individual files marked with asp2? Doesn't matter in what order?
