RC Tanks Australia Forum :: View topic - Asp - Advanced IR Features - Remora Wireless Link
http://www.rctanksaustralia.com/forum/viewtopic.php?f=164&t=995
Author:  Phyrephish [ Sat Jun 13, 2015 3:14 pm ]
Post subject:  Asp - Advanced IR Features - Remora Wireless Link
Time to look at some of the advanced features of Asp. The MAKO system is the only system on the market offering wireless updates of IR battle data. IR battle data along with system setup information can be transmitted by the Remora Wireless Link back to a MANTA LCD screen.
Author:  mikeb [ Sat Jun 13, 2015 4:41 pm ]
Post subject:  Re: Asp - Advanced IR Features - Remora Wireless Link
if you are running say 2 tanks each with Mako/Asp and Each fitted with a Remora. Does each operator have to have their own MANTA or can MANTA switch between operators?
Regards Mike
Author:  Phyrephish [ Sun Jun 14, 2015 8:15 am ]
Hi Mike
At present each Remora and Manta are assigned a channel number (videos probably here and on the youtube channel) and these numbers need to match. If you have two remora on the same channel as a single manta then the manta will not make sense of 2 remora telling it different things.
So in short - each remora requires it's own manta and both need to be on the same channel.
