@RAD
Octopus functionality is possible with ASP. HOWEVER, it would most likely have to come at the cost of losing the 4 & 6 Channel support. AND one would have to really know how to use their radio.
Octopus concept is simple but you need a programmable radio as it is the radio which assigns the "model number". It would work by assigning an offset on CH5 for each tank. For example:
On the radio you set
Tank 1 = Offset of -20
Tank 2 = Offset of -10
Tank 3 = Offset of 10
Tank 4 = Offset of 20
NOTE you can NOT use 0 which would be exact neutral of 150us
Using OPenLog you can add a "model number" which ASp would then determine to to be the offset and assign it to that tank. 4 I think reasonable, 6 possible - more ridiculous
So you know that flashing headlight that you hate
Well when you turn on the 4 tanks and the radio. Depending on what model on radio selected will determine what offset is being
output as default. Only the tank with the matching offset will start blinking the headlight and hence can be turned on.
But as I said this would have to be a firmware choice that one would upload to ASp and in the knowledge that it is at the expense of other options.
