It is currently Tue Jul 01, 2025 3:42 pm All times are UTC + 10 hours
[ 2 posts ] |
Dave62ndFF
Post subject: HL Panzer III Suspension Posted: Tue Jan 29, 2013 11:27 am |
Hi,
I noticed that after driving around for a while the suspension bolts (indicated in the attached pic) seemed to be working loose. Is this common, or just part of breaking in a new tank?
I've tightened them up for now but was wondering, if it is going to be an ongoing problem, are there any known fixes such as a plastic safe form of Loctite?
Thanks, David
Dave62ndFF
Post subject: Re: HL Panzer III Suspension Posted: Wed Jan 30, 2013 10:38 am |
Hi,
Thanks for the tip re washers. I did notice that there seemed to be a sweet spot between being too loose and actually impeding the function of the suspension. What actually brough the problem to my attention was one of the end suspension arms with the external shock absorber (as can be seen in the top right of the image I posted) working loose. After it reached a certain point the shock absorber pushed the wheel all the way down and the plastic guide on the suspension arm popped out of it's slot and ended up under the hull. End result was an overextended wheel that was locked in position. Easy enough to put back in place but something I could see recurring.
Best regards, David
[ 2 posts ] |
