RC Tanks Australia Forum • View topic - LiPo battery setup
Board index » Electronics » Power Systems
Post new topic Reply to topic  [ 12 posts ]  Go to page 1, 2  Next
 Post subject: LiPo battery setup
 Post Posted: Fri May 29, 2015 7:13 am
Can anybody advise me what I need to do to change my power setup to LiPo and what voltage I can go to; I will be running a Tiger 1 with a Mako2 setup and a King Tiger with ASP regards Mike
 Post subject: Re: LiPo battery setup
 Post Posted: Sun May 31, 2015 8:41 am
All I can say is what I tend to use
2 cell LiPos for all WWII era tanks
3 cell LiPos for Post war tanks
cheers
kg
 Post Posted: Mon Jun 15, 2015 6:45 am
Thanks Kevin; I didn't phrase the question correctly; Just like the old methods of instruction incorrect question (what do tanks run on? (grass; sand mud ;diesel etc!!)
What I should of asked was do I need any extra bits of kit; inline fuses; speed controller; brushless motors?
What amperage/voltage can I go up to? I don't want the tank to go like a rocket like some on the video's I have seen on YouTube; no way does a Tiger go like an M1 Abrams; anyhow if you could advise I don't want to have a load of molten plastic. regards Mike
 Post Posted: Mon Jun 15, 2015 7:40 am
Hi Mike
It would be hard to give specifics as each tank and more importantly tankers budget/skills are widely different. Expectations too....
If you have a high degree of R/C knowledge and some engineering skills then you might consider brushless motors for any slight improvement they may offer. But you will probably have to find/make your self some custom gear boxes and look for a specialised control board.
Personally because of the wide rage of products already available for brushed motor setups it is easier for now to stick with them. But again that's just my opinion.
Regardless, brushed or brushless, M1 or Tiger you need to have a decent programmable Radio for your tank. That is why here at RCTA you will see so much devoted to the 9X series and Taranis. You simply need all the available switches and to be able to program custom limits for each of your tanks. If you think you Tiger is going too fast it is a simple matter of adjusting down the throttle on your radio. You can do this no matter what control board you have.
Budget pretty much control what type of control board you go for and that will in turn influence your further choices.
Personal preference - do you want good sound or prefer to have smoke, IR or airsoft. In my case since I have many a Panzer III / IV I do away with the smoke altogether in preference of a decent speaker and or camera installation.
Level of knowledge/skill: Are you familiar with servos and do you wish to use them instead - What about gyros and 360 degree turret operation. All these factors come into play with choice of control board/radio & other extra items.
Personal Expectations: For me I prefer to keep it simple as the more things you want to change and the more complex the more likelihood of something not working. I prefer to be in "CONTROL" of my tank rather than have boards that "control the tank" for me. I prefer sound over smoke. I prefer to minimise the amount of metal on the tank to keep the weight at a reasonable level.
For a Tiger if I was doing up a Heng Long tank:
Get the Asiatam lower hull and metal tracks
Recoiling barrel if doing IR - airsoft for airsoft.
Visaton FRS speaker
Asp (why not they are pretty cheap for me :) )
or El Mod
Turnigy 9XR Pro with tankER9XPro and 3 x 3 position switch mod
2 cell lipo as big as will fit into the hull with speaker
These gearboxes
http://www.rctank.de/51-PRO-steel-gearb ... hort-axles
 Post Posted: Mon Jun 15, 2015 5:54 pm
thanks Kevin, you have cleared up a number of things for me ( no brushless); I know you have a lot on your plate; however it is a help to the likes of me to be able to ask what may seem the obvious; maybe you need to have a " Fahrschüler" post to help us.
regards Mike
 Post Posted: Fri Jun 19, 2015 5:24 am
Ref: "Visaton FRS speaker".
Which one ?
 Post Posted: Fri Jun 19, 2015 9:11 am
FRS-7 8 ohm or FRS 8 - 8 ohm
 Post Posted: Sun Jun 21, 2015 1:42 am
Ref ; "For a Tiger if I was doing up a Heng Long tank:
Visaton FRS speaker
or El Mod
These gearboxes
Why not just start with your list in the fist place and cancel the HL tank ?
As I am in the stupid question dept ! Tank tracks appear to be, metal or plastic are there any other's ?
Regards
 Post Posted: Fri Jun 26, 2015 1:47 am
Tank tracks appear to be, metal or plastic are there any other's ? As in Rubber type ! (more for grip)(perverts track ! ;-))
 Post Posted: Fri Jun 26, 2015 7:41 am
There are plastic tracks
There are Metal Track
and at least one model (Leopard) with Metal tracks and rubber inserts (like the real one)
I can't think of any other material from which tracks could be made.
For a Tiger get metal tracks - I only use plastics with my Panzer iii s and ivs and then only because of budget
Users browsing this forum: No registered users and 9 guests
