Code501
Post subject: Another one from the Netherlands Posted: Thu Mar 14, 2013 5:36 am |
Hello there,
I was looking for stuff for my (soon to arrive) Turnigy 9XR. Then I found this site. The Tanker9x firmware appealed to me and I want to flash it to my 9XR.
I own a Asiatam Tiger I Späte ausführung with a Benedini sound card and a (soon to be replaced) Elmod Pro.
I am also looking for a way to let the speaker output of the Benedini go through a Clark TK-22 board to minimize the amount of speakers needed. (I need two speakers now, 1 for Benedini and 1 for Clark) Maybe there is someone that can help me?
_________________ *Tiger Späte Ausführung (mit Elmod Pro und Benedini) [IN PROGRESS] *Jagdtiger Hybrid (mit 88mm und 128mm) (Clark Model TK-22) [IN PROGRESS]
Post subject: Re: Another one from the Netherlands Posted: Thu Mar 14, 2013 7:35 am |
HI Code501 Here is tankER9X (latest version) tanker9x_130101.zip You will need eePe or other 9X editor to flash to the 9XR. If you want to make both levers self-centering then there is a video on how to do this on on our YouTube channel http://www.youtube.com/user/rctanksauSorry can't help with your speaker situation as I do not know if either board uses PWM to drive the speaker or not. Cheers Kevin G
Paulus
Post subject: Re: Another one from the Netherlands Posted: Thu Mar 14, 2013 8:13 am |
Joined: Mon Feb 18, 2013 5:13 am Posts: 29 Location: the Netherlands
Hallo
Garage:
Code501
Post subject: Re: Another one from the Netherlands Posted: Thu Mar 14, 2013 7:25 pm |
@Paulus: Hallo daar.
@Phyrephish: Is it possible to use a gyro with the Tanker9x firmware? It is for something like this:
Post subject: Re: Another one from the Netherlands Posted: Thu Mar 14, 2013 8:34 pm |
Yes of course - because the the two do not interact at all. For the most part the gyro will work inside your tank automatically.
cheers kg
Code501
Post subject: Re: Another one from the Netherlands Posted: Thu Mar 14, 2013 8:44 pm |
And can you still set the sensitivity of the gyro? It uses a spare channel to do that.
Code501
Post subject: Re: Another one from the Netherlands Posted: Tue Mar 26, 2013 4:21 am |
Got a fix for the speaker issue.
See diagram below:
It is now possible to have only one speaker onboard.
