It is currently Tue Jul 01, 2025 8:45 pm All times are UTC + 10 hours
Edwin
Post subject: Re: First, just as a test if I succeed Posted: Thu Nov 14, 2013 2:51 am |
Again, it goes a little further.
The Resinmaster are now cleaned and the flaws I have been milled, which takes incredibly long. So now I could touch up with 2K filler this.
Tomorrow they will then sanded
Edwin
Post subject: Re: First, just as a test if I succeed Posted: Sat Nov 23, 2013 1:39 am |
Thus , in small pieces precedes it .
I now have first made me a little form , so that I can recognize and assess problem areas better. Because an error costs only a fraction of the material and the time that is necessary in a spin cast .
The resulting casts are as I did not expect at wide error-free , but now I know where I must begin . It is also a good test whether the chain so fit and works as I imagine it . I once put a piece of 1/16 chain next to my chain links . The 4 members now weigh even as much as a small chain .
In addition, I have also tried the same , the strength of the chain , but at 1200 N train me the wooden backing of the links is broken without that I could impress the chain.
So now I have started to build the spin cast , which is very expensive . I use to drive silicone, which is then crosslinked in the oven.
For cutting I use the pressure lids .
And so I work now the master link into the mold.
Since I now have a lot of work , partly because the shape is not as usual in two parts, is special consist of 8 parts because of the complicated shape of the chain links .
