First, just as a test if I succeed http://www.rctanksaustralia.com/forum/viewtopic.php?f=9&t=765 |
Page 3 of 3 |
Author: | Edwin [ Thu Nov 14, 2013 2:51 am ] |
Post subject: | Re: First, just as a test if I succeed |
Again, it goes a little further. The Resinmaster are now cleaned and the flaws I have been milled, which takes incredibly long. So now I could touch up with 2K filler this. Tomorrow they will then sanded |
Author: | Edwin [ Sat Nov 23, 2013 1:39 am ] |
Thus , in small pieces precedes it . I now have first made me a little form , so that I can recognize and assess problem areas better. Because an error costs only a fraction of the material and the time that is necessary in a spin cast . The resulting casts are as I did not expect at wide error-free , but now I know where I must begin . It is also a good test whether the chain so fit and works as I imagine it . I once put a piece of 1/16 chain next to my chain links . The 4 members now weigh even as much as a small chain . In addition, I have also tried the same , the strength of the chain , but at 1200 N train me the wooden backing of the links is broken without that I could impress the chain. So now I have started to build the spin cast , which is very expensive . I use to drive silicone, which is then crosslinked in the oven. For cutting I use the pressure lids . And so I work now the master link into the mold. Since I now have a lot of work , partly because the shape is not as usual in two parts, is special consist of 8 parts because of the complicated shape of the chain links . |
Page 3 of 3 | All times are UTC + 10 hours |
