Boris Plotnikoff
Post subject: M10 Tank Destroyer Posted: Thu Jan 16, 2014 8:18 pm |
Joined: Thu Jan 16, 2014 6:46 pm Posts: 18 Location: 92320 Chatillon France
Hi,
I have some interesting informations for thoses who want to make a M10 Tank Destroyer but they are on my computer and I dont know how to process to transfer pictures on your site.
Can you help me ?
Thanks in advance, I remain.
Boris Plotnikoff
Post subject: Re: M10 Tank Destroyer Posted: Fri Jan 17, 2014 7:40 am |
Hi Boris
Underneath the big text box in which you write your post there is the 'Upload Attachment' area. Directly under the [Submit] button.
In Filename use the Browse Button to select the file from your computer then click "Add the file". The file will then upload to the site.
To place the picture in your post - select where you want the picture to go and click the "Place inline" button.
Note it is best to have your pics about 800 px wide but up to 1000 will be OK.
Boris Plotnikoff
Post subject: Re: M10 Tank Destroyer Posted: Fri Jan 17, 2014 5:06 pm |
Hi,
I will try !
The 3-inch gun motor carriage M 10 Tnk Destroyer I've made is done on the Heng Long Sherman basis.
All the upper structure and turret are made by myself .
I will post the following picture in new post, it seems to me that I ca post only 3 pictures at each time.
Regards.
Boris Plotnikoff
Boris Plotnikoff
Post subject: Re: M10 Tank Destroyer Posted: Fri Jan 17, 2014 5:12 pm |
Hi,
pictures of the work :
Following pictures on the nex post.
Boris
Boris Plotnikoff
Post subject: Re: M10 Tank Destroyer Posted: Fri Jan 17, 2014 5:17 pm |
Hi,
next pictures :
Following pictures on the next post.
Boris
Boris Plotnikoff
Post subject: Re: M10 Tank Destroyer Posted: Fri Jan 17, 2014 5:22 pm |
Hi,
Next pictures :
Boris
Boris Plotnikoff
Post subject: Re: M10 Tank Destroyer Posted: Fri Jan 17, 2014 5:54 pm |
Hi,
Next pictures :
Following and last pictures on the next post.
Boris
Boris Plotnikoff
Post subject: Re: M10 Tank Destroyer Posted: Fri Jan 17, 2014 5:59 pm |
Hi,
The following pictures will be the last of the serie.
All the upper hull and turret are made with 1 and 2mm thick plastic card. The gun bearing mount is modified according with the front armoured mask and the Heng Long gun elevation servo is deleted for a RC mini servo located on the right side of the turret
The M10 TD is paint with French 1st Armycolours , 7th Regiment de Chasseurs d'Afrique, 4th Squadron (capt. Guth ) 1st platoon ( Lt. René ).
I had 8 years old when this tank participate à the liberation of a small town Gex in the south of Jura and I've came up on this tank at this occasion, souvenirs !
Best regards.
Boris
Boris Plotnikoff
Post subject: Re: M10 Tank Destroyer Posted: Fri Jan 17, 2014 9:07 pm |
Hi,
two pictures of the M 10 TD taken the September 3 1944 :
Duguesclin 7 RCA Gex aout 1944 Photo Jean Carrier.jpg Duguesclin 7 RCA Gex aout 1944 Photo Jean Carrier. 2 jpg.jpg
I was photographied on this picture !
Best regards.
Boris
Admin
Post subject: Re: M10 Tank Destroyer Posted: Sat Jan 18, 2014 10:19 am |
nice work there Boris, thanks for posting
