RC Tanks Australia Forum • View topic - I need a set of connectors for the Heng Long RX18
Board index » Electronics » Control and IR Battle Systems » Heng Long RX
Post new topic Reply to topic  [ 3 posts ]
 Post subject: I need a set of connectors for the Heng Long RX18
 Post Posted: Mon Jan 27, 2014 4:47 am
Kettenrad Driver
Kettenrad Driver
I am rehabilitating a nine year old HL Tiger 1 that had a main board die some years ago. This particular model is so old that it does not have an RX18 and it has soldered in wiring.
Where can I find the wire connectors that I need to put this tank back together and connect the wiring to the RX18?
Many thanks!
 Post subject: Re: I need a set of connectors for the Heng Long RX18
 Post Posted: Mon Jan 27, 2014 8:20 am
HI There
The connectors used by Heng Long are JST-XH connectors. If you do a search on eBay for JST-XH you will find them. However, these connectors are mostly used for LiPo batteries and hence you will find lots of connectors under 6-way. You might find it hard to get a 8-way but they are there.
For a one off job you could get away with crimping the wires with some needle nose pilers and then add a bit of solder. To crimp properly you will need to get a crimper.
http://www.ebay.com/itm/Engineer-PA-21- ... 2a36e143e0
I can vouch for the PA-21, I use it all the time. There are some way more expensive crimpers and some cheaper ones.
 Post Posted: Tue Jan 28, 2014 5:53 am
Kettenrad Driver
Kettenrad Driver
I found a source in Hong Kong for a decent price that includes shipping. Please note the product description for why it would not show up on the search...
Thanks for your help.
