RC Tanks Australia Forum • View topic - ASP Model files for the radio.
Post new topic Reply to topic  [ 8 posts ]
 Post subject: ASP Model files for the radio.
 Post Posted: Mon Aug 08, 2016 3:14 am
Hey, this might be a stupid question, but where can I download the ASP 2 model files for the radio? Im using a 9xtreme and a 9xr Pro, but I think the model files are compatible. In both of them I have installed 4 pos switches and replaced the pot for the six pos switch.
I know how to put te files in the controller and all the stuff. Thanks in advance!
 Post subject: Re: ASP Model files for the radio.
 Post Posted: Mon Aug 08, 2016 1:18 pm
Sorry Rad
I have just spend over 1 hour writing a reply to this explaining how a single ASp2 model file for users with 6 pos switches will not work for everyone only to lose it all. I can not belive how much info was lost.
You will just have to understand that there is no ASp2 model file setup for 6 pos switches because EVERYONES setup is going to be different. Radio -firmware -wiring,.....
I can provide a model file based on my setup and you will have to look at it and understand how it goes together. IT WILL NOT be a 100% fit for everyone
For everyone else
PLEASE NOTE you do not need ANY special files or radio for ASp2 - Asp1 and 2 work fine with a simple 4 channel cheap as radio. With anything knowing how to use your radio is important.
 Post Posted: Mon Aug 08, 2016 1:33 pm
Sorry about that missing post...
Of course I understand it. If you can send me your model file to my email would be great.
 Post Posted: Tue Aug 09, 2016 7:18 pm
Good luck
ASP2-6Pos.zip
Again - If you do not have your radio setup exactly the same as mine then this model file may confuse you more than help you. It is for a 9XRPro using eeskype.
6-pos switch (P3) is assigned to CH20 and mapped with curve 17. There are better curves in the newer firmware
This model file also includes the Radio Edit Mode setup (mode 6)
 Post Posted: Wed Aug 10, 2016 6:13 am
Great, thanks. I only need to wait until my ASPs arrive...
Just in case it does not work, it would come in handy to have an updated functions and setup list like this ones: http://rctanksaustralia.com/guides/index.php?title=Asp But with the newer features.
 Post Posted: Wed Aug 10, 2016 7:46 am
All that info was in the huge post reply that I lost. :(
I have started an Asp2 guide page here:
http://rctanksaustralia.com/guides/index.php?title=Asp2
Basically everything is the same the main change is that with the 6 pos switch there are now options at -85, -70, 70 & 85 on CH5, CH6, & Ch7 (plus the previous -100, 100, -50 and 50)
These are:
CH5
-100 toggle headlight
-85 toggle reverse light
-70 toggle headlight PWM (IR) OR extra sound switch (Airsoft) Sound 110
-50 toggle Aux light
50 toggle smoke
70 toggle Ele motor (Advanced) OR extra sound switch (general) Sound 119
85 toggle Air motor (IR) OR extra sound switch (Airsoft) Sound 120
100 Engine toggle/Shutdown
CH6
-100 User Sounds A - Engine revs, radio chatter (2 x 4 sounds)
-85 User Sounds B - Damage state/explosions (2 x 4 sounds)
-70 User Sounds C (4 sounds)
-32 to 32 - volume control
70 User Sounds D (when engine off - plays music folder 02 on Card A)
85 User Sounds E (4 sounds)
100 User Sounds F (4 sounds)
CH7
-100 Machine Gun 1
-85 Machine gun 1 & 2
-70 Machine gun 2
70 Main cannon AP round
85 IR request OR additional User sound trigger (sounds 103 & 104)
100 Main Cannon
 Post Posted: Wed Aug 10, 2016 6:33 pm
 Post Posted: Wed Aug 10, 2016 8:29 pm
Yes the above is also true for the Asp1 update. All of these new options are now available for Asp1 EXCEPTING
CH5
These switches are still there but there is NO headlight PWM or reverse light control on Asp1 so you can use these as additional user sound switches
Users browsing this forum: No registered users and 13 guests
