It is currently Tue Jul 01, 2025 12:05 pm All times are UTC + 10 hours
Post subject: Voice Command Files Posted: Tue Jul 05, 2016 10:17 pm |
Hi All
For those of you updating Asp will not that you also need the new voice command files if you are planning to use the Radio Setup function or even going through the test procedure. These actions will work without the sound files but it is easier to know what is going on with voice prompts.
There are basically 2 sets of files
All of the voice descriptions which are located in a folder named: 01 on ModuleA
and
Spoken numbers 1,2,3,... located in a folder also named: 01 on ModuleB
You can download them here:
ModuleA_01.zip
ModuleB_01.zip
Post subject: Re: Voice Command Files Posted: Sat Aug 27, 2016 3:09 am |
are these included in the tiger sound files you included with asp2, and the bulldog set you posted, or do I need to load them in? Thanks
Post subject: Re: Voice Command Files Posted: Sat Aug 27, 2016 8:08 am |
Hi Peter
They are there. This page is old and refers to Asp1. All your voice files will be there. The voice files are all in the 01 folders.
On module card A the 01 folder contains all of the specific voice statements On module card B the 01 folder contains all of the generic voice files like numbers, one, two,....
Feel free to re-record these as I have tended to use computer generated voices to save time.
There is also a 02 folder On module card A the 02 folder is your music player folder - you can put the latest album you are listening to there and use your tank as a jukebox
The 02 folder on B does nothing as yet.
Post subject: Re: Voice Command Files Posted: Sat Aug 27, 2016 1:56 pm |
Ok, thanks!
