It is currently Sat Jun 28, 2025 10:07 pm All times are UTC + 10 hours
[ 1 post ] |
kamaz
Post subject: Permanent battery assembly Posted: Sat May 14, 2011 2:49 am |
I just hate to open battery compartment, unplug battery socket and plug in charger every time I need to charge my HL tanks, that is why I came up with this permanent assembly so all I have to do now is put main switch in off position and plug in charger. ŠEMA NAPAJANJA.JPG Now, you can notice that in off position main circuit board (RX-18, but it can be any other HL mother board, RX-14/13 or TK-01) is in short circuit, but this is the original connection from HL main switch too, and this is to discharge several capacitors on RX, so when tank is switched on, is will not jeark or go out of control. Also notice that I have devided swich in two sides/zones for you to easily see where to connect what cable. Switch is for two serarate circuits swiched at the same time. You can also use that ˝old˝ switch that HL put in tank (right one on the pic above).
A little hint: you can install small connector between charger (positive lead) and battery, and negative lead and battery, so that you can disconnect battery from circuit to stop it from leaking out when it is not used for long time.
[ 1 post ] |
