So, have you all noticed that those front lights of TK-01 motherboard tank light up only when tank is moving foward?
Well, that was annoying to me, so I had to do some soldering...
First, you need to cut off that orange line going from TK to that 8 pin connector for upper hull. That is positive pole giving around 2.5-3V of power. (negative is connected to battery negative input line/cable)
Secondly, you need to locate two lines for hull front lights, they are green (positive) and white (negative) and cut them off some 1-2cm from TK.
Third step is to install back light(s) and conect them. Now, on scheme there is only one light, because this is for mine german tanks---back light is here column light...
Fourth step is to solder all up. It would be very nice if you would do some little pre-soldering test.
How does it work?
When you switch lights before you switch main switch, nothing is on. But when you switch main switch, lights start working after a second. (this is due to some capacitors on the way)
If you have switched main switch first, but then lights, they will light up instantly.
Since this is not the best solution, lights will dim a bit when tank goes back.
