MAKO2017
Post Reply
phyrephish
MAKO2017
Post by phyrephish » Wed Apr 05, 2017 10:55 pm
After many requests the MAKO is making a return for 2017. So if you are looking for an economical and simple way to make your Heng Long or Taigen Tanks compatible with the Tamiya battle system then look no further.
If you are new to MAKO, this system has been around for many years now where it has been consistently updated and improved. MAKO is without a doubt is the most flexible and feature packed IR battle system on the market. MAKO has so many features that it is often confused for being a full tank control unit. MAKO is an IR interpreter that senses IR signals from the various R/C Tank battle systems and converts them into a signal that the attached MFU can "understand". Similarly, MAKO transmits the IR signals of the most common R/C Tank battle systems. This is the functional core of MAKO. In addition to this MAKO provides for the setting of a number of different weight classes and operational modes. The number of operational modes is dependant on the the main tank control system being used. The highest number of modes is reached using RCTA's Asp. Additionally, MAKO provides support for a recoil servo, relays and can display battle information on a Manta/LCD.
MAKO2017
MAKO2017 is designed to be used exclusively with Heng Long and Taigen RX-18 style tank control units BOTH 27 mHz AND 2.4 gHz operation. It's inception has come about after many requests for a return of MAKO2 and MAKO_TE. MAKO2017 is a combination of these two boards and is priced halfway between at $35 USD.
Features:
  • Ir battle compatibility with all Tamiya based systems, PLUS Heng Long and Taigen tanks
  • Includes 2-shot kill Tamiya code capabilities
  • Multiple weight class/mode selection
  • Realistic magazine option
  • Main cannon Xenon flash or LED support (1)
  • Recoil Servo support (2)
  • Manta LCD display (3)
  • Additional signal out (4) can be used to stop track recoil*
  • Programming & testing using a SONY TV remote
  • Firmware update port
  • Heng Long/Taigen and Tamiya/RCTA battle unit outputs
* NOTE Output 4 can be used to trigger relay/s to cut the automatic track recoil and other automatic track movements (hit shakes & death spasm). The IR hit shakes and death spasm can always be cut out. However, the effectiveness of removing the track recoil will depend on the version of MFU. MAKO2017 is triggered by the factory IR pulse from the tank MFU. If the track recoil is timed with this pulse then it will be cut. If not track recoil may only be partially cut.
MAKO2017 Connections
Connection of MAKO is very simple as it resides in between the MFU's IR output port and the battle unit (Mushroom and IR emitter). Connect the supplied 5pin cable from the MFU's IR port to the input port on the left side of MAKO. Connect the existing 5pin battle unit cable to the 5pin output port on the right hand side of MAKO (not actually shown). The pic below shows connection to a Tamiya or RCTA style battle unit (5 + 2 pin arrangement). This is all that is required for basic operation.
To make use of MAKO's additional features a Xenon flash or LED can be connected to output 1. A current limiting resistor is present on the board making the LED connection a breeze.
If servo based recoil is wanted connect a servo direct to output 2.
If you want to be fancy you can connect a MANTA LCD to output 3. This will then display your IR battle setup and status.
To remove unwanted track movements connect a 2 channel relay module to output 4. Such relay modules are readily available online for less than $2 USD
http://www.ebay.com/sch/i.html?_odkw=re ... l&_sacat=0
MAKO2017 Documentation:
MAKO2017 QUICK START.pdf
(608.47 KiB) Downloaded 1869 times
MAKO2017 REFERENCE GUIDE.pdf
(437.72 KiB) Downloaded 1860 times
Demo videos to follow soon.....
ArmouredRCWorkshop
Re: MAKO2017
Post by ArmouredRCWorkshop » Thu Apr 06, 2017 10:05 am
Excellent News
I have emailed you already !
Gary
Post Reply
