MAKO Taigen V2 Compatibility Update
Post Reply
phyrephish
Post by phyrephish » Tue May 08, 2018 10:58 pm
It has taken a while but finally I have got the info required on the changes made to the Taigen IR signal. You will see below update files for both MAKO 2017 and MAKO 2018.
NOTE:
1. Even though the files say MAKO2018 it will also work with MAKO2017
2. There are 2 update files with suffixes _A1 and B0. Please update with _A1 FIRST then _B0
MAKO2018_V3c.zip
(4.49 KiB) Downloaded 1614 times
MAKO2018_V3c.zip
(4.49 KiB) Downloaded 1604 times
phyrephish
Re: MAKO Taigen V2 Compatibility Update
Post by phyrephish » Fri Jul 06, 2018 2:36 am
What's NEW in MAKO_V3:
First up a big thanks to BaEng from RC Tanks Malaysia, who has help test MAKO with all of the newer Taigen and Heng Long MFUs. Hopefully, this latest update (July 2018) addresses all issues experienced when battling against these newer MFUs.
* Fixed Taigen V2 send and receive IR signal
* Fixed Heng Long 5.2 & 5.3 send and receive IR signal
* Improved overall IR signal decoding
* Firmware filename and program date now displayed during info requests [0] on Sony TV remote.
Sony TV remote can now be used to check some of MAKOs functions
Press [--/-] to test IR fire signal
Press [Repeat] to test IR hit receive *
Press [TV/AV] to test Repair function
Presss [0] to read MAKO setup on MANTA LCD
Press [Power} to reset MAKO
* NOTE: TV remote will send as ID# 666. This way you can check the operation of the friend or foe function by setting your MAKO to an ID# starting with 6
Want some info on HOW TO update your MAKO see this post
viewtopic.php?f=31&t=71
Post Reply
